Used when ospf adds inter-area routes to kernel routing table or leak inter-area routes to other areas as summary routes. %action%: the possible string should be "add", "leaking" and "unable add". %pent%: the pointer of the pent. %pent_ip%: the IP address of the route. %pent_mask%: the IP mask of the route. %hop%: the number of next hops to the destination. %cost%: the Type 1 cost to the destination. %cost2%: the Type 2 cost to the destination. %type%: the pent type. %lsai%: the associated pointer of LSA structure. %tentbucket%: the hash key in PATH.
None. This is for debugging.
Debug-Verbose
%action% route pent %pent% %pent_ip%/%pent_mask% numhops %hop% cost %cost% cost2 %cost2% type %type% lsai %lsai% tentbucket %tentbucket%.
| Name | Type |
| action | String |
| pent | Ptr |
| pent_ip | IPN |
| pent_mask | IPmaskvalN |
| hop | uInt |
| cost | uInt |
| cost2 | uInt |
| type | uInt |
| lsai | Ptr |
| tentbucket | uInt |
